Почему не приняли эту фотографию (или редактируем фото), Вопросы, критика, помощь... |
#41
Вам поможет программа XnView.
Меню Правка -> Метаданные -> Экспорт EXIF и сохраняете в txt -------------------- Гельминтолог (С) Ammendorf
#42
Участник ![]() ![]() Группа: Пользователь Сообщений: 46 Регистрация: 3.9.2009 Из: Санкт-Петербург, Пушкин Пользователь №: 4536 ![]() |
[Camera]
Camera Manufacturer : FUJIFILM Camera Model : FinePix S1600 Orientation : top-left (1) X Resolution : 72 Y Resolution : 72 Resolution unit : Inch Software : Digital Camera FinePix S1600 Ver1.03 Date modified : 2010:07:17 22:40:46 YCbCr Positioning : co-sited (2) [Image] Exposure time [s] : 1/220 F-Number : 8.0 Exposure program : Landscape mode (8) ISO speed ratings : 64 EXIF version : 02.20 Date taken : 2010:07:17 22:40:46 Date digitized : 2010:07:17 22:40:46 Components configuration : YCbCr Compressed bits per pixel : 4 Shutter speed [s] : 1/223 Aperture : F8.0 Brightness : 9.42 Exposure bias value : 0 Max aperture : F3.1 Metering mode : Multi-segment (5) Light source : Unknown (0) Flash : No flash Focal length [mm] : 10.4 FlashPix Version : 01.00 Colour space : sRGB EXIF image width : 4000 EXIF image length : 3000 Interoperability offset : 26856 Focal plane X-Resolution : 6494 Focal plane Y-Resolution : 6494 Focal plane res. unit : cm (3) Sensing method : One-chip color area sensor (2) File source : DSC Scene type : A directly photographed image Custom rendered : Normal process (0) Exposure mode : Auto (0) White balance : Auto (0) Scene capture type : Landscape (1) Sharpness : Normal (0) Subject distance range : Unknown (0) [IOP] IOP index : R98 IOP version : 0100 [Makernotes] Maker Note Version : 0130 Quality Setting : FINE Sharpness : Normal White balance : Auto Flash mode : Off Flash Strength : 0 Macro mode : Off Focus mode : Auto Slow Synchro Mode : Off Picture Mode : Landscape Continuous/Bracketing Mode : Off Blur Status : None Focus Status : Ok Exposure Status : Ok [Thumbnail] Compression : 6 Orientation : top-left (1) X Resolution : 72 Y Resolution : 72 Resolution unit : Inch Thumbnail offset : 27028 Thumbnail length : 2813 YCbCr Positioning : co-sited (2) |
#43
#44
Все то-же, мыльность. С таким фотиком, похоже, все фото будут такие.
#45
![]() Активный участник ![]() ![]() ![]() Группа: Пользователь Сообщений: 68 Регистрация: 8.12.2009 Из: Туляк однако ))) Пользователь №: 4555 ![]() |
Все то-же, мыльность. С таким фотиком, похоже, все фото будут такие. Не факт. Я с этого Фуждика фото видел, конечно как и любой мыльницы предостаточно касяков с изображением, но в целом на фоне своих собратьев ультрозумов он весьма неплохие фото выдаёт. Так что причина скорее всего в другом... Сейчас к сожалению не могу открыть эти кадры, Радикал чёт глюче. Но вчера открывал и судя по увиденному я думаю это результат неверных настроек сжатия для веба. Автор фото, выложте пожалейста какойнибуть один необработаный полноразмер, попробуем выяснить что к чему. Можите мне на почту скануть если опасаетесь что отсюда "турнут". -------------------- Отъявленный фотоманьяк.. х)
#46
http://s60.radikal.ru/i170/1008/5f/19d8b04fdecb.jpg необработанный ЧС2т
у aqura тоже s1600 |
#47
#48
http://s60.radikal.ru/i170/1008/5f/19d8b04fdecb.jpg необработанный ЧС2т у aqura тоже s1600 Мндя, первое что вижу что сюжет с таким дер..ым ещё и неконтрастным освещением явно не лучшее условия для получения хорошей детализации. При том для любой фототехники, а для мелкоматричного мыла темпаче.. :-(( Второе это ISO200, что в купе с паганым малоконтрастным светом и сценой только усугубляет то что працессор мыльницо нашарпомылил.. Чесногря тут даже для зеркалки сложновато буде, но она-бы справилась (особенно те у которых не слишком много мегапикселей) и кадр был-бы пр. таким как на нижнем фото в моём посте, не идеальный тоже но с существенно лучшей детализацией (особенно если снимать в RAW). Ну да чё получилось. Пожато как есть. ![]() Пожато после обработки. ![]() Пс.На будущее - отключите в камере насколько возможно все шумодавы и старайтесь придерживаться минимального значения ISO. А так-же полезно снимать в приоретете диофрагмы (на s1600 он есть, "А" режим) где диофрагму стоит зажать (если позволяет кол-во света) на пару стопов от открытой (то-е с 3.3 на 5.6). Это с потрей света но несколько улучшит детализацию по углам. -------------------- Отъявленный фотоманьяк.. х)
#49
можно попросить обработанное фото в ориг размере и если получится выложить?
#50
http://s61.radikal.ru/i173/1008/5c/d8b52681372f.jpg здесь с освещением все нормально мне кажется (тоже оригинал), и у s1600 можно выбирать только большее или меньшее значение диафрагмы
#51
можно попросить обработанное фото в ориг размере и если получится выложить? Блин, а я полноразмер-то и не стал после редакции отдельно сохранять.., сразу перевёл в размер 1070х800.. ![]() Оть, провёл пр. такую-же обработку. ![]() Как писал ранее, обработка не спасаёт. Только внешний вид несколько лучше делает (тени-света, контраст-цвет). http://s61.radikal.ru/i173/1008/5c/d8b52681372f.jpg здесь с освещением все нормально мне кажется (тоже оригинал), и у s1600 можно выбирать только большее или меньшее значение диафрагмы Оо.., здесь я-бы не сказал что всё нормально.. Здесь прямо скажем всё хреново, совсем всё. По порядку.. По контрастно-световой сцене почти такое-же гау..о как и на предыдущем примере (по лучше но всёравно таксе), единственное что свет падает с более благоприятного угла и нет таких глубоких теней. В целом вполне можно получить нормальный кадр и мылом если-бы... Если-бы не касяки при самой съёмке. 1) 400ISO (нахрена спрашивается !) - итог те детали что не сожрали шумы добил ацкий шумодав (на процессорном уровне неотключаемый кстати).. 2) Фокусные 23,6мм.. Это на данном аппарате эквивалентно пр. 320мм для 35мм формата. Что привело достаточно узкой зоне резкости даже у камеры с такой маленькой матрицей, как следствие резким оказался только лок (куда видимо и наводился автофокус) а всё остальное ближе и дальше этой зоны размыто.. На телеположении (читай зумм) снимать вполне можно (даже зеркалками с гораздо большим размытием), но осторожно продумывая последствия для композиции и кадра.. В данном случае лучше было подпустить ближе и снять на хотя-бы среднефокусном положении объектива чтоб не было проблем глубиной резкости. Вобщем не самый лучший (особенно для данной фототехники) свет и пункт №1 + №2 = здравствуй мыльный кадр.. ![]() Насчёт работы диафрагмы завтра попробую раздобыть 1600тый Фудж и глянуть что там с настройками диофрагмы, но она должна свободно выбираться в любом значении (в пределах технически доступного). -------------------- Отъявленный фотоманьяк.. х)
#52
![]() Активный участник ![]() ![]() ![]() Группа: Пользователь Сообщений: 308 Регистрация: 9.5.2006 Из: Сергиев Посад Пользователь №: 64 ![]() |
http://s61.radikal.ru/i173/1008/5c/d8b52681372f.jpg здесь с освещением все нормально мне кажется (тоже оригинал), и у s1600 можно выбирать только большее или меньшее значение диафрагмы Ну, я сам снимаю не очень хорошо, но все же посоветую выставить режим приоритета диафрагмы, открыть ее на максимум и вручную ставить ISO64 или 100. Не больше. Для матрицы 1/2.3 ISO100 - это максимально приемлемая по шумам чувствительность. Ваш снимок можно было бы снять при ISO100 и выдержке 1/250 - получилось бы лучше. QUOTE 2) Фокусные 23,6мм.. Это на данном аппарате эквивалентно пр. 320мм для 35мм формата. Что привело достаточно узкой зоне резкости даже у камеры с такой маленькой матрицей, как следствие резким оказался только лок (куда видимо и наводился автофокус) а всё остальное ближе и дальше этой зоны размыто.. Не, я по калькулятору ГРИП глянул, все от 20 метров до бесконечности резко (если на гиперфокал наводить). У мелкоматричных фотоаппаратов ГРИП просто огромная, ее можно вообще не учитывать, только в макро. PS. Вообще я в ужасе - Фуджи-6500 на ISO800 так не снимает. |
#53
Не, я по калькулятору ГРИП глянул, все от 20 метров до бесконечности резко (если на гиперфокал наводить). У мелкоматричных фотоаппаратов ГРИП просто огромная, ее можно вообще не учитывать, только в макро. PS. Вообще я в ужасе - Фуджи-6500 на ISO800 так не снимает. Ну незнаю-незнаю.., там ЯВНО видна глубина резкости.. Кстати не только в макро но и на телеположении (на зумме), что собственно и наблюдаем-с.. Сёнять у знакомых глянул s1600тый, там и правда управление диофрагмой странное оказалось - доступны только два значения дофрагмы (как в "А" так даже и в "М"), только максимально открытая и максимально закрытая. ![]() Шозанах и кто так из ыНжынеров соорудил, но итог наврно забить на управление диофрагмой на Фудже s1600том.. А вот ISO на минимум эт аназначна (о чём выше и писал). S6500 да, хорошая машинка. Из УЗ по картинке одна из лучших в своём классе, только где она теперь.... ![]() Из недорогих УЗ остались в продаже только всякое мелкоматричное с кучей безумных (для матриц 1/2.3) кол-вом мегаПУКселей..... -------------------- Отъявленный фотоманьяк.. х)
#54
#55
конечно можно
#56
#57
Вы каждый раз будете писать в эту тему, когда Ваши фото не выложут, могу сразу сказать, что фото не проходят по качеству изображения. И в дальнейшем, наверно, будет то-же самое! Вроде все хорошо и фотограф Вы хороший, но фотик жутко мажет, даже 183 и ту загубил.
#58
Вы каждый раз будете писать в эту тему, когда Ваши фото не выложут, могу сразу сказать, что фото не проходят по качеству изображения. И в дальнейшем, наверно, будет то-же самое! Вроде все хорошо и фотограф Вы хороший, но фотик жутко мажет, даже 183 и ту загубил. + 1 Автор, ну ладно где пасмурно но вот смотрю на дневное фото и вижу опять эти ..%№$@&... 200ISO....... Ё%№..та НАХРЕНА они эти 200исо впёрлись ярким днём ??? Вам ведь выше уже писали что ЕДИНСТВЕННАЯ возможность получать более-менее приличное качество фото с этого девайса так это НЕ ИСПОЛЬЗОВАТЬ чувствительности ISO выше 100 !!! (а лучше 64ISO) Опять в шайтан-автамаде (или сценах) снимали ? А потом жалуетесь шта фото не приняли.. ![]() -------------------- Отъявленный фотоманьяк.. х)
#59
#60
(уменьшил для более нагядного просмотра) ![]() ![]() Дополнительные коментарии думаю не нужны ибо сделано всё в пару кликов... ![]() -------------------- Отъявленный фотоманьяк.. х)
Текстовая версия | Сейчас: 6.9.2025, 15:40 |
